Old 05-24-2021, 01:47 PM   #13
Jasper7821
Thank You,
I'll try and remove the flanged shaft and hopefully the clip is still there and not in the transmission.
[QUOTE=Gilles;636038]
Originally Posted by Jasper7821 View Post
It would be awesome if that's all it is, I not seeing it. what the C clip rest against. If the slot for it is on the outer side of the splines on the flanged shaft I ca see how maybe the flanges shaft is just pushed into the transmission supported by (#13) radial shaft seal. I don't see what the C lip is used for if it sits on the outside of the splines.
If it sits on the inside of the splines, then wouldn't it rest up against the (#5) thrust washer of the (#11) differential pinion and if so, how would the clip stay closed until it made it past the pinion.
And if the clip did come off/break inside the transmission, how would I remove it.
The circlip works as a spring, once you get it on it's grove (on part #15) just push it into position and hit it with a brass hammer and will click into place..
Jasper7821 is offline   Reply With Quote
