Old 05-22-2021, 09:53 AM   #1
boxxster
Thanks for the suggestions everyone. I initially thought it was some sort of overheating issue too, I just don't understand why it would overheat after 5 or 10 minutes, then be perfectly fine for half an hour after I take the fuse in and out. Again, swapping the bulb and ballast did not correct the issue.
There's no corrosion on the connector and all the wiring looked good when I had the headlight out. Might take it out again just to be 100% certain though.
Darren, nice to know I'm not crazy and that someone else is having the same issue. PLEASE let me know if you find the problem. I am in Burlington btw.
