Old 05-20-2021, 11:27 AM   #1
Contr_eras
If you're only doing rears, you should try to match up with what's on the front. You defn don't want to put ceramic on the rears and have std material fronts. Different characteristics between the two materials and will give quite different results in the cold, heat, and rain. If you want to go ceramic, either wait until you can do all four corners or do all 4 corners now.
I'm not sure what brand is on the front but I know that they are ceramics.
Contr_eras is offline   Reply With Quote
