Old 05-09-2021, 09:32 AM   #1
ike84
Their removal releases the chains so that the IMS shaft centers in the case opening rather than being pulled to one side by the chains.
That's interesting. One thing I have read about IMS bearing failure is that some shafts (and hence the bearing) seem to be off centered and that this eccentricity leads to bearing failure. Do you think that removing the chain tensioners before IMSB install and then reinstalling at the end eliminates this problem?
Sent from my POCOPHONE F1 using Tapatalk
