Old 05-07-2021, 07:00 AM   #5
steved0x
steved0x's Avatar
Originally Posted by PLP View Post
Second - what changes, features activation, or such to perform?
If your car doesn't have the on board computer (4 stalks, blinker, wipers, cruise control, on board computer) and doesn't display the outside temp on the dash, you can enable the OBC in durametric (both enthusiast and pro, if you have a rental it is most likely pro) and you will get that temp display. It is a neat feature.
You can then later wire up a switch if you want all the OBC features, on my 2000S, I just have the temp display (was already done before I bought the car...)
https://www.pelicanparts.com/techarticles/Boxster_Tech/91-ELEC-turn_signal_switch_-_OBC_upgrade/91-ELEC-turn_signal_switch_-_OBC_upgrade.htm
Edit - looks like this might not work for your year according the article, my bad
