the wire is cut, the other end is where the cut is. It wont be hard to find, it will be right by the TB. Just solder the wire and be done with it. You dont want to replace the wiring harness, it isn't as easy as you might think it is and will need to drop the engine, at least a good amount if not all the way out.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
