Old 05-03-2021, 02:40 PM   #11
Zordrack
Originally Posted by john12312 View Post
Thanks. I checked it out and the mic is a tight fit into the trim piece. I'm afraid to force it and break the trim piece. I'm thinking I might be able to fish a line through the opening to the back and pull the mic cord through. Did you not use the foam covering?
I dissembled the mic, removing all the plastic, so I was left with just the capsule itself at the end of the wire.
Then stuck the foam around the capsule, both for fitment and pop filtering/decoupling, and crammed foam wrapped capsule into the rear of the trim piece right in the middle.
Getting the wire through the console was a pain in the rear, but everything else seemed to fit really well.
2000 Boxster S Manual
Zordrack is offline   Reply With Quote
