Thread: Ruroh Raggy!
Old 05-03-2021, 01:01 PM   #1
Blue devil
Yeah, I will just get the new wire harness and that should take care of all the codes. My question is where the other end connects. I can see the connection to the throttle body sensor (?) on the plenum but not sure how much I will need to remove to get to the buried end. Looks like the whole upper manifold?
QUOTE=blue62;634557]To JPF's reply you can get Marine grade solder connectors that you crimp on lightly then heat with a lighter or small torch.
They solder to the wire and also have heat shrink as part of the connector.
So if you use them your connection is soldered and also moisture proof.
Napa carries them.[/QUOTE]
Blue devil is offline   Reply With Quote
