Old 05-03-2021, 12:35 PM   #11
Zordrack
I never did take pictures of it.
I guess I should have so I could have done a proper writeup.
But it's fairly simple once you get the cluster off.
Biggest pain with that is releasing the connector for the hazard switch.
But after that you can simply pop out the mic trim piece with a trim tool and the mic capsule will just squeeze into the cavity in the back of the trim piece where the OEM mic would normally go.
It friction fits, but with just enough give that it wont pick up too much noise from the car.
2000 Boxster S Manual
Zordrack is offline   Reply With Quote
