Thread: Ruroh Raggy!
Old 05-03-2021, 10:57 AM   #2
blue62
Originally Posted by Blue devil View Post
Well @piper6909 looks like you were right. I ran the codes and they showed P0121,P1121, P1122 and PO452. I decided to check out the throttle body and this is what I found was something had chewed up the wiring coming from my throttle body. So, at this point, I should be able to figure out what part to buy to connect to the throttle body but can’t figure out what the other end of the wires connect to. Looks like I may have to remove the top of the manifold?
Your codes are for the throttle position sensor.
Looks like the wiring may unplug from the sensor at the throttle body.
So when you find the other end there should be another plug-connection some where along it.
Looks like all you need is a new wiring harness.
Or splice the chewed wiring.
