Per the Bently Electrical wiring diagrams EWD-54 that red wire feeds a 40amp Maxi fuse at Relay support 2. The Maxi fuse powers the relay and SAI pump so you will just remove. The blue wire on EWD-15 is to the charge indicator (Voltage gauge) as you previously stated.
