Old 05-01-2021, 05:24 PM   #2
Oli
Originally Posted by PaulE View Post
I have the CTEK version of the Porsche battery maintainer. I'm going to guess that the power socket you have your charger plugged into has a GFI outlet somewhere else on the same circuit and the GFI has tripped. I just verified if I unplug my CTEK from power, but leave it plugged into the cigarette lighter in the car, I can cycle the power button on the CTEK through the motorcycle, car, optima battery and snowflake positions. I actually had the same issue as you a few years ago. I thought the CTEK had died and bought another on Amazon, only to have the same issue. I learned there was a basement outlet with a GFI on the same circuit as my garage outlet and it had tripped. I returned the new maintainer and the original one is still going strong for 17 years now!
I have the same problem, what did you do to get the top row of lights to come on?
Also, where did you find that most unusual fuse.
Oli is offline   Reply With Quote
