Old 04-27-2021, 08:43 AM   #1
Kboggs
Kboggs's Avatar
Fyi, since my 99 does not have the lug in the fuse panel, I made a set of 986 jumper cables to keep under the passenger seat. In case you ever lose the emergency cable or want to save time, you just need to apply 12v to both poles of fuse C3, and the remote fob will operate the power door locks and allow you to pull the lever to pop the frunk. I took some alligator clips and leftover stereo install wire and made a long set of cables i can connect to someones battery, clip to ground at door, and shove this fuse adapter in fuse C3 and have the frunk open in one minute flat. Good insurance policy and backup to some of the other methods, snd since the earlier years do not have the pullout plug in the panel to attach to.
Kboggs is offline   Reply With Quote
