Thread: Alignment help
Old 04-22-2021, 02:41 PM   #2
Kboggs
Kboggs's Avatar
OP, did you do any refreshing on the rear LCAs? You only mention working on the front. You may need to replace the bushings that mount the rear LCAs to the body. These bushings are just like the fronts and when they get old will not let you get to factory specs. They do wear out.
The rears have new struts, drop links, and sway bar bushings, and track arms. May do the rest next year, heard spring sag could contribute also.
Kboggs is offline   Reply With Quote
