Old 04-22-2021, 05:33 AM   #1
itsnotanova
Originally Posted by almostcrazy View Post
Good, the power steering line has a small kink in it but I'd rather see if it works first cause that line rather expensive.
I took a picture of the passenger side of the other line that received damage. Again this is on the the passenger side in front of the rear wheel next to the jack point. I've circled the broken line.
Looks like the short side is broken. That will make it cheaper than any of the longer lines that go to the front. You shouldn't have a hard time finding someone to ship you the short lines. The longer ones should be found locally if you can
Woody
