Old 04-19-2021, 08:19 AM   #2
spongebob
If you are going to use the built in amp in the HU you will need to run new wires to the speakers since the wires to the speakers are wired to the factory amp....or...use the factory amp.
Using the factory amp is not going to happen. I believe is the worst part in the system. Will create an adaptor harness of an old amp as suggested here earlier. Realise I will need to pull 8 new speaker cables through the firewall This was what I was trying to avoid by using the old cables that went to the Nokia amp
spongebob is offline   Reply With Quote
