Old 04-18-2021, 07:16 PM   #7
KevinH1990
KevinH1990's Avatar
I installed a Sony XAV-AX5000 in my wife's Toyota. If you are using the same or similar unit connecting the handbrake cable on the wiring harness to ground, that will take care of that connection.
Check post #14 of this thread if you need to find the reverse signal wire:
http://986forum.com/forums/boxster-general-discussions/51283-does-anyone-know-vss-wire-02-bose.html
I agree with Cunningr - exercise caution in cutting the wiring harness. You never know when you or a later owner will want to update your work.
