Old 04-18-2021, 04:05 AM   #12
Traco
Can you hear the pump whirr when you turn on the ignition without starting? You should be able to hear the fuel pump priming and building pressure. If you can't then start there.
I just checked mine and you will need to listen very carefully as it's a faint noise.
Traco
_________________
Older but no wiser.
2003 Boxster S, Seal Grey
Traco is offline   Reply With Quote
