Old 04-14-2021, 12:15 PM   #1
Homeoboxter
Originally Posted by pilot4fn View Post
When the fans kick in, the temp creeps up another 0,5 C (to 100,5 C) and then comes down pretty quikly.
When I did the test, I had been driving over an hour. Turned the engine off, connected the Durametric, restarted the car and let it idle while occasionally given a bit or addittional rpm. This whiel following the actual values on the temperature with Durametric.
Yes, that`s totally fine, I did the same and had the same reading. Sorry for the confusion, my comment was referencing to the OP`s post about the temperature "still creeping up". I`m just wondering if the OP confirmed that the high temperature that he sees is indeed out of the normal range, i.e. way over 100C.
Homeoboxter is online now   Reply With Quote
