Old 04-14-2021, 12:04 PM   #4
pilot4fn
Same in mine. When you are saying the temp is still creeping up, did you actually look at the temp value how high it goes up to? Boiling temperature is completely normal. Does it go any higher than that?
When the fans kick in, the temp creeps up another 0,5 C (to 100,5 C) and then comes down pretty quikly.
When I did the test, I had been driving over an hour. Turned the engine off, connected the Durametric, restarted the car and let it idle while occasionally given a bit or addittional rpm. This whiel following the actual values on the temperature with Durametric.
2001 996 C2 Manual
pilot4fn is online now   Reply With Quote
