Old 04-11-2021, 11:48 AM   #16
piper6909
piper6909's Avatar
First of all, once you lock the front pulley at TDC, do not even think about removing the pin and rotating the engine. The correct way to unbolt the TC is to do that BEFORE you lock the engine at TDC, NOT AFTERWARDS. Once the IMS retrofit is complete and the engine is back together, you can install the trans with the TC on it and rotate the engine by hand to get the bolt holes to line up. It is all a matter of sequence.��
I think he's got that, he's trying to reinstall the tranny after the IMS and RMS has been done. What I can't understand is why the TC is locked up. Do you lock the TC when removing the tranny? Why isn't it spinning for him, unless it's not seated all the way in the tranny and putting too much pressure on the flex plate.
2010 Subaru Forester
