Old 03-30-2021, 04:02 AM   #10
10/10ths
"50 Years of 550 Spyder"
10/10ths's Avatar
Wow...
....so you guys apparently do not read my posts.
See that part where I said,”..on START UP.”
Yes, the water burns off, but not instantly.
ON START UP, when your parts are dry, you are pumping this water diluted oil throughout your engine.
The water displaces the oil from the bearings and acts as a cutting agent against the internal parts, and prevents not only proper wear protection from a solid oil film, but also prevents the cam chain tensioners from acting quickly.
You ever get a lot of chain noise on cold starts?
But fine, save yourself the $100 bucks.
Again, oil is cheap, engines are expensive.
You bought a freaking Porsche. Spend the money for proper maintenance.
Out.
