Old 03-29-2021, 12:39 PM   #6
Black Knight
Kermits finger = bacon
Originally Posted by Chboro View Post
I think I may have been a little paranoid concerning the smell. Oddly enough I had 2 new front tires put on the same day. Smell is diminishing and I think it was from the tires. However just now I did jack the car up, remove the rear wheels and check all the tubes for leakage. During the tube install I had cleaned that area really well and it looks leak free and all the tubes are flush and o rings seem to be seated properly. I intend to keep an eye on it. Thanks for the responses.
It is probably the brake cleaner or whatever other solvent you might have used to clean off the old oil from the heads when you replaced those tubes. It will cook off after a few miles of spirited driving and you should be back to normal. Sounds l like that might be what it was and has already remedied itself
Black Knight is offline   Reply With Quote
