Old 03-24-2021, 12:35 PM   #2
Jgkram
I decided to do this over a nice weekend last October. I do not have a garage so I had to wait for some nice weather. I started taking the old top off when I got home from work on Friday and finished the install Sunday afternoon. I worked at a steady pace and definitely took time to double check myself each step of the way. I am pleased with the glass top although I have not tried to service the engine. I hear it does not fold up as far as the plastic window so it limits the area available. Be aware the rear view is quite a bit reduced however it's really nice to be able to see through crystal clear glass. I do believe the acoustic material also helped with the noise level although that is really subjective. The biggest issues I had were; fitting some side tabs that are blind (see the Roaring Tigers youtube), getting some glue on the top (but it cleaned off easily) and replacing a plastic retaining strip that holds my headliner (the original broke and i had to wait on a replacement part). I took tons of photos during my teardown as reference notes and I highly recommend doing that if you choose to do this yourself. Several folks have commented on the job and asked me to replace their tops (which I've declined). Again good luck whatever you decide.
Jgkram is offline   Reply With Quote
