Old 03-23-2021, 06:52 PM   #11
Stl-986
believe you are way over thinking it. If your concerned, just drain the coolant and replace it. It's an easy job and pretty cheap. With what your 1st & 2nd plan is you will spend more time doing that then it takes to just drain & replace. As long as whoever put it in last didn't use DexCool you wont need to even worry about the tests.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
