Old 03-19-2021, 11:37 AM   #10
porschefan76
porschefan76's Avatar
Originally Posted by freserf View Post
As long as you have DGPS, the accuracy is centimeters ... most handheld GPS don't have that capability ... I had to modify mine with a DGPS antenna when I was first learning about them. Basically you have close enough to hurt someone using only the satellites ... adding the D, gives you coordinate correction based on a physical location on earth. This gets you close enough to vaporize your target. I was involved in marking locations at a shipping port so we could keep track of the location of each container. Took a while to get the data, but very much improved the location checkers job.
Hi freserf, so I'm just trying to understand, are you trying to theorize a more accurate approach to operating an odometer than what the 986 uses?
The 986 literally uses a sensor that counts rotations and multiplies that by a constant, some statistically validated constant, that attempts to account for the variable diameter of all possible tires offered on the vehicle. It is not complex at all. Most other vehicles also use this method.
porschefan76 is offline   Reply With Quote
