Old 03-15-2021, 08:06 AM   #5
Banana S
FWIW, when I discovered that the bushing was missing on my car, I simply replaced it with a 50-cent rubber grommet from AutoZone that I happened to have lying around. It works fine. (EDIT: Okay, I just pulled up the OEM part number and I see that it's only a buck thirty-two... Even I'm not so cheap as to refuse to pay that. I'll probably order the OEM bushing the next time I order something from Pelican Parts. Cheers!)
2002 Boxster S, 6 speed, Speed Yellow
Flat Six Innovations 3.8L Stage II Track Performer, RoW M030 Suspension, B&M Short Shift Kit, Fabspeed Bypass Pipes, FVD Brombacher "Sound Version" Muffler, UD Pulley, Low Temp T-Stat.
Banana S is offline   Reply With Quote
