Old 03-09-2021, 05:42 AM   #1
Qingdao
Qingdao's Avatar
Originally Posted by Brad604 View Post
If you don't want to be under the car when its on jack stands (understandable) then add a second safety system. make yourself some cribbing from 2X4s or 4X4 fence posts or something. It would not be difficult to add that and then you know you are very safe down there.
Partially loading the suspension would lessen the safety under the car. You are basically removing some of the force on the jackstands and making the car less stable.
Those lift points are in that place for a reason. There is a reason why professional mechanics don't lift cars by both the tires and the lift points.... just the lift points alone.
OP if the thought of jack stands toppling scares you then you can always take your jack stands and weld or bolt a big ole plate of steel to their base to increase its size and decrease the risk of it toppling over.
'98 PP13B powered "RX986"
