Old 03-07-2021, 08:22 AM   #12
blue62
Originally Posted by CharlesE View Post
I drive it alot and i dont drive slow so i know its gets warm enough. I did notice a really slow coolant leak but I dont know where its coming from I just see the level drop every month or so. Could this be a factor?
First thing to do is pressure test the cooling system and see if you can determine why your coolant level is dropping and where it is going. Once you know the answer to where the coolant is going you will know if you need to be worried about the moisture on the oil filler cap or not.
