Old 03-05-2021, 10:42 AM   #20
Luckyman01
average "wrench" kind of guy
This is totally achievable if you have time, tools and space.
I did have the advantage of a friend with a lift.
Between the 101 peojects, the bently book and utube there is enough info out there.
I did find "burner" usefull.
I did buy all parts in advance including the notorious bearing fix.
Hindsight being 20/20, I found a beautiful bearing in place.
I did replace it as I had the part, however if I did it again I would inspect the IMS being in place first. The one in my 2000S likely did not need replacing.
I found the boots split so I added that to the project. (dont forget new hardware if you take the axlex off at the transmission).
This is something you can do, take your time.
Luckyman01 is offline   Reply With Quote
