Thread: p1602
Old 02-26-2021, 05:27 AM   #1
blue62
Originally Posted by DWBOX2000 View Post
Friends new 99 Boxster is showing p1602. No warning lights, runs great. What does that mean?
When you say there are no warning lights am I correct in assuming you mean no check engine light????
I am not positive about this because DTC or P codes can be specific to the year of the car.
The P1602 code is for an open,or no voltage in the main voltage supply circuit. It is most likely triggered due to a dead battery or disconnected battery at some point in time.
This info is for a 2000 boxster with a 7.2 DME/ECU
I can't find any info on the code for a 99 Boxster and I am not sure which era of DME/ECU the 99 uses.
So if you have no check engine light ,I would clear the code and see if it returns over time.
Keep me posted on what happens I like to know end results. Helps me with my car and helping others
