Old 02-26-2021, 03:46 AM   #1
CrisZenithBlue
CrisZenithBlue's Avatar
The e-bake on all the 986 base cars are a different diameter than the S e-brake, and require changing the rear carrier assemblies in order for everything to fit and work, period. Any state with vehicle inspections will require the e-brake to function, and while that may not be a problem for you, it makes the car unsalable in any state that does. And if the car came into my shop for a PPI, I would tell the buyer to drop the price by the amount necessary to correct the problem, which is not small project.
As 80-85% of the car's braking effort in on the front brakes, you won't notice any difference.
JFP, i really appreciate all the insight and your expertiese on this. I might end up getting the bigger brakes for the front and leaving the rear base stock. I'll look more into it and see what i end up doing.
CrisZenithBlue is offline   Reply With Quote
