Old 02-25-2021, 04:48 PM   #13
porschefan76
porschefan76's Avatar
just curious, could a Dry fuel injector Seal could cause a vacuum leak..?
Hi Gilles. Having just replaced all of my fuel injectors, on the fuel rail side, I think you'd have a fuel leak (pressurized fuel rail). On the intake manifold side, I suppose you would have an vacuum leak, yes.
If you have to replace your injectors or o-rings, I used a small amount of the recommended white lithium grease on all of the o-rings and it really made everything go back together nicely and prevents the o-rings from twisting upon insertion. Thanks!
Last edited by porschefan76; 02-25-2021 at 04:49 PM. Reason: added some words to clarify
porschefan76 is offline   Reply With Quote
