Old 02-23-2021, 08:13 AM   #1
kcriqui
Originally Posted by ike84 View Post
In my experience, better rca cables will not fix it most of these. There are two types, problems with rca cables and problem with the power source, but the power source is very common and not easily fixed. It has to do with electromagnetic interference, often times generated by the alternator (notice that it gets higher pitched with higher rpm). Good amps have filters built in to address this problem. It's one reason why cheap amps are cheap.
Sent from my POCOPHONE F1 using Tapatalk
The crazy thing is, this isn't alternator noise. It happens when the ignition is on, but the engine not running. Pressing the accelerator changes the volume of the noise, not the pitch. It sounds like a dirty pot, kind of scratchy as I move the pedal and different throttle positions result in the noise getting louder or completely silent.
kcriqui is offline   Reply With Quote
