Thread: 2.5" exhaust
Old 02-17-2021, 02:08 PM   #15
911monty
911monty's Avatar
See the First Law of Thermodynamics (Law of Conservation of Energy) and Boyle's Law.
Originally Posted by ike84 View Post
No way dude, I used a level 5 hex to actually cause the gravitational pull of the crankshaft to accelerate flow at the level of the expansion...
Joking aside, I'm not sure I follow you there. Bernoulli's principle certainly dictates pressure inversely proportional to flow velocity over a surface, but that is not the same as pressure within a cylinder. Boyle's law states they are the same I don't disagree with the fact that this will slow gas velocity at the expansion, and a decrease in flow velocity will certainly change flow dynamics,(Bravo you are correct! The flow dynamic you reference is a conversion to pressure which is the point. Reference the First Law of Thermodynamics) especially at the boundary layer (between turbulent and laminar flow). But, minimizing heat loss through the system (hence the wrap) should mitigate this and maintain the desired pressure gradient per the ideal gas law (PV= nrt, keep the nrt equal and P and V move in opposite directions) and Pousielle's law (restriction of flow through a tube is inversely proportional to the the 4th power of radius)
If your statement is correct - i.e. change in pressure is directly proportional to the cross sectional area of flow, this would mean that an infinitely large expansion (i.e. from an exhaust tube to the atmosphere) would create an area of infinitely large pressure. If that were the case, then I think we just turned our exhaust pipe into a rocket booster?!?
And this is just being ridiculous according to the First law of Thermodynamics and energy Conversion which states that energy is not created or destroyed it is converted
That is, unless I have completely misunderstood what you were getting at.
