Old 02-14-2021, 11:00 AM   #2
The Sandman
The bleeder valve tab should not come apart. There should not be visible wear on the rubber where the tab sits. It sounds like your vale is worn out/damaged and dumping coolant before it reaches normal operating pressure.
I'd watch that area when you do the pressure test.
Attached pressure test kit to overflow tank cap with a tight seal, cold engine. System holds *no pressure*. Heard air leaking around the bleed valve. Put some water around the valve, and saw bubbles near one of the screws where bleed valve cover attaches to overflow tank. No obvious cracks and no pink fluid in trunk.
Bolts are tight so didn’t feel the need to overtighten.
Are next steps replacing the bleeder valve, o ring, etc, or ?
Dave
The Sandman is offline   Reply With Quote
