Old 02-10-2021, 02:18 PM   #11
Muskoka Minute
Muskoka Minute's Avatar
Originally Posted by obthomas View Post
Bart, I'll be more than glad to help you any way I can. But you need to do the coding because if I were to do it I have no way to check my work except to tear my boxer apart and put your cluster in my Boxster to see if it works. I did that once for the cluster I just sold but I don't want to do it again. So get your cluster ask advice if you needed I can supply you with the. Bin file for the proper coding and
Provide advice.
OK. Thanks and much appreciated.
I didn't realize it was such a complicated process.
Cheers!
My Beast 2004 Boxster SE #0174
- 3.8 with all the internal goodies, Under-mount Pulley, IPD Plenum, 996 Intake, Softronic Tune, 987 Factory Sport Exhaust, skid plates, IMS solution, Ohlins R&T, RSS Toe Links, Camber Plates, Michelin Pilot Super Sport on all 4 corners, Alpine Double Din c/w new speakers & amps.
Muskoka Minute is offline   Reply With Quote
