Old 02-03-2021, 10:19 AM   #6
Farmlifer
Veteran & Boxster Padawan
Farmlifer's Avatar
Originally Posted by rexcramer View Post
FYI, be careful not to over-tighten the screws for the burp valve. They are easily stripped. You can also order the valve's two O-rings to rebuild your existing valve.
What do you think is appropriate good fingers around extension tight or good screwdriver handle twist? I can’t find any DIY videos or info on replacement and torque really...
2003 Boxster / Speed Yellow / DRL Hack
Farmlifer is offline   Reply With Quote
