Old 01-29-2021, 07:38 AM   #28
blue62
Originally Posted by kbod View Post
welp. I tried to put a clamp on the evap hose and I tried clamping numerous hoses and the car didn't care. Runs lumpy and barely struggles to stay running, If i disconnected a vacuum line it just stalls. smells extremely rich upon startup, For the camshaft deviation ill probably just fiddle a teeny bit with the timing, not that hard. but for the lumpy terrible idle I have no idea whats causing it or how to fix it. is my camshaft deviation enough to cause this? I don't know. I assume the car not starting after putting fuel is its own isolated issue with the evap system. I am going to purchase a smoke kit to overall see if there are any big vacuum leaks that are causing this. I checked the codes, cylinder 1 2 and 3 missfire along with the p1341... how weird....
Your lumpy idle is most likely caused by a combination of the Camshaft deviation range and an issue with the EVAP system.
The missfires are due to the Camshaft Deviation being so far out of spec.
As to the Camshaft Deviation I would try to fix that first. Seems like you are a tooth off or a link off in your set up.
Your actuators for the Variocam system seem to be working ok now as when you rev to 3000 RPM you get a change of 25 degrees of actual cam angle. So that is right on spec.
So it is a timing issue, not an actuator issue.
I would Concentrate on getting the Camshaft deviation correct on bank 1. because you have The Camshaft Deviation numbers to view that tell you if it is fixed or not.
Then the other issues will be easier to find and correct.
Yes the issue with not starting after refill is caused by a problem with the EVAP system. I believe your EVAP issue is also "part" of your lumpy idle issue.
