Old 01-25-2021, 09:27 PM   #1
puravidabahia
Originally Posted by puravidabahia View Post
thanks for the input, i am certain it was bosch on the maf; i am getting ready to just replace the MAF again along with all O2 sensors to see what changes, if anything; the idling is intermittent but usually acts up after being off when at running temp and if not moving out of gear it will sometimes just stall, forcing a restart;
and yes, all stock equipment......i just had a minor service, fuel filter and air filter with no change on the symptoms........higher rpm is fine, only the stopped and/or idling has issues plus only the refuel problem but that is only when refueling when it fails to fire up and causes several restarts after cutting out.....once i force it thru that with 1/4 to 1/2 mile of driving that issue goes away
puravidabahia is offline   Reply With Quote
