Old 01-25-2021, 09:23 PM   #1
puravidabahia
one would have to look at some data like O2 sensor waveform and fuel trim waveform under various conditions. perhaps something like O2 sensor signal bias is an issue.
Meaning if your O2sensor signals are biased lean then the system will try to adjust by adding fuel. But it is unlikely that both sensors have the same issue and only in a certain RPM range.
The hard starting situation at fill up followed by poor running-- does that only happen at fill up?
How does the car run off idle? Mid range RPM and upper range RPM?
Is the car stock? Stock exhaust? Stock air filter?
Oops sorry just reread your original post and see that O2 sensor was replaced.
thanks for the input, i am certain it was bosch on the maf; i am getting ready to just replace the MAF again along with all O2 sensors to see what changes, if anything; the idling is intermittent but usually acts up after being off when at running temp and if not moving out of gear it will sometimes just stall, forcing a restart;
puravidabahia is offline   Reply With Quote
