Old 01-16-2021, 07:33 AM   #11
porschefan76
porschefan76's Avatar
Wow, this community is awesome. Thank you all for continuing to follow along and helping. I've currently got my heater running in my garage trying to break it into the 50's so I can get some work done today.
Originally Posted by Zzorro View Post
Likewise.
My codes are clear after changing out all 4 O2 sensors, but still get lingering short periods of bogging, or lack of power. Have never stalled.
I've got my Durametric data and it appears that my pre-cat O2 sensors are working as intended. I'm fairly certain my post-cat are working properly as well, as they maintain a steady mV reading at idle, but they do change as the revs change. So, I haven't considered changing those yet, but might be something I'll do if it's recommended. Again, I've got my data and plots if anyone wants to dig in, but this is not my profession, so I only know what I've read about this data/plots.
Originally Posted by Brian Minson View Post
I had a 2001 986 as well with the same issue and ran thru all those fixes as well. Have you REPLACED the MAF?? Just an idea.
Here is the 986 DIY playlist of videos I did on my car's issues.
https://www.youtube.com/playlist?list=PLbBMHPz04qDW2lbqUZ4p2yWK9joftSOEO
Brian
HTTP://986Brotherhood.com
I actually make reference to your video in my OP. They were very helpful and helped clarify things when I checked for fuel pump volume and fuel regulator pressure checks, so thank you! I was really hoping my problem was fuel pressure as it has a tendency to backfire into the intake and lope similar to your car in the video when it's cold, but not when warmed up.
I'm really hoping replacing the fuel injectors gives some results, because after that, I'm not even sure which animal to chase next. As I mentioned above, my bank 1 camshaft deviation is out of spec, but not enough to throw a code, so I am not sure if that is contributing to the issue or not.
porschefan76 is offline   Reply With Quote
