Old 01-12-2021, 02:24 PM   #2
porschefan76
porschefan76's Avatar
First, thank you both for responding so soon.
blue62
Do you still get the P1126 code?
Is it the only code you get?
Any pending codes?
P1126 is the only code I get legitimately. When I ran with MAF disconnected I got some codes for the MAF, but not since reconnecting. Also have not gotten P1126 back since first time. No additional pending codes.
JFP in PA
I'd start pulling the fuel injectors, looking at the tips for carbon fouling.
RKAT is the adaptation value near idle.
FRA is the adaptation value under load and further divided into FRAU (lower load range ) and FRAO (higher load range) ranges (perhaps the durametric doesn't display these divisions).
The RKAT values near idle are used to change the length of the injector pulse to account for deviations from ideality (ie intake leaks) to maintain the proper O2 sensor reading. The RKAT value is an additive factor and can deviate by +/- 4.5%. The FRA value is a multiplicative factor and can deviate by 1.32 to 0.70. The positive values or values greater than 1 increase the injector pulse length to account for a lean mixture, and negative values and values less than 1 are to compensate for a rich mixture.
Great, as soon as it gets warm enough to mess with the plastic window, I'll pull the fuel rail and look at the injectors as I change them.
I guess Durametric tool does not divide further because I do not see FRAU or FRA0.
RKAT values of -2.4 indicates rich at idle and FRA 1.3 (positive) is lean above idle then correct? I was considering smoking the intake again but if it's over-rich at idle, likely unwarranted?
Anything else I should be checking? Thank you for your time!!
porschefan76 is offline   Reply With Quote
