Old 01-12-2021, 12:43 PM   #20
blue62
Originally Posted by kbod View Post
I found some diagrams, yes the hoses are for the secondary air injection system but there were no codes present other than the p1341... along with the generic missfire code after a while of driving
Well that is interesting I would have expected SAI related codes as well as the P1341 code.
If you have access will doing the other work you should check that entire SAI system over.
There is an Air change over valve, a electric vacuum switching valve, a non return valve, and a vacuum reservoir.
an issue with anyone of them and you have constant SAI related codes.
Keep us posted
