Thread: IMS center bolt
Old 01-08-2021, 10:38 AM   #18
Homeoboxter
A better and permanent fix would have been to install a plug behind the bearing, as is done in all IMS Solution retrofits. The IMS shaft tube is weak enough without drilling drain holes into it.
Actually I drilled the sprocket through while pinning it to the shaft:
The idea is that centrifugal force is constantly pulling oil from the tube through this hole while receiving oil from the crankcase through the open end.
