Old 01-04-2021, 09:56 AM   #5
Homeoboxter
Odd situation.
Have you replaced the Cam position sensor on bank 1 yet?
When you replaced the Cam actuator/solenoid did you check to see if there were the proper number of chain links between timing marks on the Cams?
+1 on checking the sensor. If the actuator was bad, that shouldn`t affect cam deviation much, only the actual cam angle. If you are in doubt regarding the actuator and solenoid, you can directly inspect them using a borescope. But it`s more likely that something is off with your sensor or timing.
Homeoboxter is online now   Reply With Quote
