Old 12-17-2020, 11:43 AM   #19
Jasper7821
Thank you, I watched a few YouTube videos of 986 wheel bearing changes. But yes, the service manual would’ve great.
The Bentley Porsche service manual describes the procedure (with pictures).
IT is pricey around $95.00 but for general service and maint. it is about all that is available. It describes the process and tools well enough that even a novice should be able to do the task.
I suggest that as a first step you purchase the Bentley service manual.
Then you have a means of reference for not only wheel bearing replacement but many other service maint. procedures.
Then after reading,up on an issue (such as wheel bearing replacement) you will have a better idea of if you are capable of doing the job or if you need to hire it out.
The other thing is to be sure it is a wheel bearing you are hearing and not something else. Sucks to spend money and do work and replace parts to find out you didn't fix the problem.
Jasper7821 is offline   Reply With Quote
