Old 12-15-2020, 04:34 PM   #1
JayG
On the slippery slope
JayG's Avatar
I've got a set of Camber Plates available for sale.
In my experience, without camber plates or adjustable LCA's, you'll struggle to get much more than about -1d camber on the front. I ran closer to -3d with my most recent setup, and I was still regularly cording the outside edge of the fronts; though this may be more about the track, than the setup. I could've probably dialed-in a little more bar, but I was afraid that would put in more understeer.
Moosport; I think we've communicated, yes? If not, I have for sale:
Billstein struts with M030 springs.
M030 sway bars
Camber Plates
Adjustable Drop-Links (one set Tarrett Front, one set SPL Rear).
forum member PCarferher is ALSO selling a complete set of M030 struts & bars. ('cuz he bought my Ohlins coiloivers & Tarret bars )
I was just going to say that. You wont get more than -1deg without camber plates or adjustable LCAs. Without lowering springs or plates or LCAs, you will probably max out around -.75 deg. The ROW M030 setup (or other lowering springs)will get you around -.25 additional front camber
You will most likely still have understeer with -1deg
2004 996 Targa Tip
Instructor - San Diego region
