Old 12-11-2020, 11:16 AM   #2
blue62
Originally Posted by Luckyman01 View Post
2000S with 120K, no mods
David
I don't find the P0442 code for a 2000S in my Bentley book but lets assume it is the same as the P0442 code for earlier year Boxsters.
You have done recent work on the AOS and the Evap system.
The P0442 is for a micro leak in the Fuel tank ventilation system.
Relates to the Evap system.
I believe all your other codes which are O2 sensor related are triggered by the micro leak in the fuel tank ventilation system.
So I would find and correct the micro leak problem first.
Then erase all codes and see how you go.
You may have not gotten something just right when you worked on the Evap system.
Or disturbed something when doing work on the Evap or AOS.
Let us know how you go I always like to know end results.
