Old 12-09-2020, 01:17 PM   #2
Homeoboxter
It matters more than you might guess; this seal MUST be installed to the correct depth, which is why Porsche released a tool that does this perfectly every time.
I can`t remember now if I just eyeballed it or I measured the 13 mm distance all the way around based on the manual, but this should be doable properly without the tool:
It certainly helps though to have it, I think the tool you are referring to is called 9699.
